01 Tahoe electrical problems
I have a 01 Tahoe, and it had a small electrical problem. I noticed the shifter was hitting a cut out wire, but one night I moved the shifter and it completely shorted out my a/c controls, tow/haul button, windshield wipers, the “PRND321”/miles and my gas fuel gauge. Any help on what might have fried or what. Please and thanks!
If you are lucky, just a fuse blew.  Fix where the short is, replace the fuse, and you are good to go.
If wire/insulation melted, then you are in big trouble.
Thanks for the reply! I’ve fixed the wire already, and I even checked all my fuses. All the fuses are good. Problem still persist
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
