2015 Silverado
Just bought a 2015 Silverado with about a 6” lift and I think only 25s on it, would have to check... but my gas mileage is 12.3 per gallon.. seeing if there is any way to help maybe get a couple more mpg besides lowering it? Willing to pay for the mileage I’m getting but looking to see if there’s anything I can do to help it.
