5 minutes ago, tlaw91 said:
Contaminated hydroboost systems aren’t common but they do happen.
I’ve also heard abs modules staying ‘on’ and holding brakes.
Also,
Double check pushrod length/adjustment, make sure there’s free play in the pedal, if the rod is too long, or adjusted too far in, it’ll hold the pistons inside the master beyond the compensator ports and never let pressure bleed off after applying brakes
I could understand the pushrod being the wrong length if this issue started after changing the master cylinder, but it didn't.  The rod can't change lengths on its own, and even if it could, it would get shorter, not longer.   It really is acting like a compensating port being covered or plugged.  Easy way to test is to remove the cap from master cylinder, and using a clean rag, make a funnel shape around the open cap and have someone tap the brake pedal.  The brake fluid should spurt out the opening as the brake pedal tapped.  If nothing comes out, try the other cap, assuming it has two caps.
I went through a bunch of cars with oil in the master cylinder when I was working at Firestone in the 80s.  A local gas station attendant used oil to top off the master, this was back when they would actually open your hood to check oil and fluids.  Every rubber part that the oil hit swelled up.
You have to swap it over when you change the cylinder.
Unfortunately with the way this whole deal shook out, unclear if he
A. Needs ABS module
B. Left contaminated oil in system when changing parts (unknowingly) and a new part is bad
C. Did something incorrectly, or some combo of the three.
When you’ve replaced the entire brake system other then the abs and it’s doing the same thing ur options are limited. And yes abs modules can do this.
I think I might have a breakthrough.  I drove it today and it started to drag to the point it was almost locking up.  I got out a d loosened the master cylinder from the hydro boost and that released  the pressure,  so I drove it home loose and put washers on and drove it the rest of the day and no dragging.  So I hope this did the trick. Thanks for your advice and help...
Sounds like pushrod length issue. Glad we helped, that was a tough one. Hardest issues I’ve ever had is when you fix the issue but then cause another with the same symptoms. I hate cars.
It sort of defies logic.  The push rod getting longer would be going against physics.  If the jam nut came loose, I would expect it to get shorter since becoming longer means it has to overcome the static pressure in the master cylinder.  You will want to unbolt the master cylinder and slide it off the studs so you can take a look at the push rod.  Having never seen behind a master on a hydra boost system I am just assuming the push rod can be removed this way.  The push rod should have a lock or jam nut preventing the rod from turning on its threads.  Be careful to avoid losing the current installed length.  Using washer as you did is a good way to help diagnose it, but is not wise to leave it that way.  You sure this didn't start after the master was changed?
I know I'm scratching my head also. The dragging of brakes  is what got this all started. There was 2 stuck front calipers  that might have been the original problem, and after fixing that mybe the pushrod might have continued the problem.  I don't know...
  • 3 years later...
On 6/9/2020 at 9:47 PM, Purplejchild said:
I know I'm scratching my head also. The dragging of brakes  is what got this all started. There was 2 stuck front calipers  that might have been the original problem, and after fixing that maybe the pushrod might have continued the problem.  I don't know...
Man...
I am so happy to have found your post.  I've been trying to solve this exact problem for the past month.
This was my post <---
After replacing the Brake pedal sensor switch, Front: Wheel hub Assembly, Rotors, Brake Pads, Calipers, and I even replaced the trailer brake module for the cherry on top.   And just like you, the damn brake drag is still there.    I've been trying to explain this to everyone and it feels like I'm the only one with this problem until I read your post.  I've only been able to drive locally before it gets so bad that it almost seizes. Like you, no codes have been thrown that I can relate to the issue. The next step for me was to replace the brake hoses and then the MC.  But since you mentioned you performed these steps I'll skip it and put the $$ towards the GM technicians.   I just dropped her off yesterday and the guy said he doesn't seem to think its a brake problem, but more likely an electrical problem.  Said they'll need the truck for a few days to comb through the wires...(sounds cheap, gulp)
This is old post but hopefully you can share your memory of the final fix?
Edited by BrianBrianBrian
  • 3 months later...
Also,
Would the pushrod come out of adjustment on its own?
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 779 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
