Front 4WD Hub Replacement
Just wondering if any one has had to replace their front wheel bearings (4WD Hub) on a new body style truck. Mine went out a few nights ago. Any one have a part number of idea of what these things cost from the dealer? I have a feeling it will be expensive since it has the ABS sensor in it..
Matt
Both of my front wheel bearings failed and were replaced while the truck was under warranty. I got the truck stuck in water up to the rocker panels and I'm pretty sure when this happened that water entered the bearings. Since they were replaced I've put over 40,000 miles on them and don't foresee them failing again soon.
I believe that this is an end-user installable part and with the exception of a socket for the spindle nut should not require any special tools.
Part number 15740291, available from GMPartsDirect.Com for $107 each. I understand that these guys make money on their shipping charges. I've had good luck getting jobber pricing by calling the parts counter at various dealerships, asking for pricing and availability for the part number I need, telling them I'm sending my driver to pick up the part, and then going down to get it myself. Your mileage may vary.
Before ordering this part, confirm that it is correct for your application. This part number is for "4wd, Front, Vacuum Brakes". The part for my truck is 15042868, which is for "4wd, Front, Hydraulic Brakes" and has an eight lug pattern.
This assembly includes the ABS sensor and pigtail as well as the wheel studs already installed. It is not handed (same part for both sides).
I have one of the old ones that was replaced. If you'd like me to, I could take some pictures of it off of the truck and e-mail them to you.
Good Luck!
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,002 Guests (See full list)
