2015 silverado mirrors
Hello!
I am looking into buying tow mirrors for my 2015 Silverado 1500 LT Z71.
I don't have power folding or heated mirrors currently but they do power adjust obviously.
My question is, how do I know if they are already wired up for blinker capabilities without tearing my door panels off?
I know certain trims have certain options and I would like to know if I need to buys a wiring harness, and learn how to wire this up before just diving in.
Let me know, thanks!
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,276 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
