Afe 49-34101 Vulcan Series
Hey all...just recently picked up a 2020 high country and I'm thinking about adding a cat back. Does any one here have any info on the afe Vulcan series cat back? The part number is
49-34101.
I have emailed Borla and Gibson about the crew cab standard bed trucks and there reply was they were working on it.
If any one on here has any information about the afe cat back please comment..thanks
I have the afe vulcan exhaust on my 6.2. I pre-ordered it when it first came out. With the 4" mid pipe and 3" tail pipes it has a very deep tone to it. I really like the sound of it. You can definitely hear all of the dfm shenanigans going on though. It does have a little drone to it because of its low pitch. Sound is so subjective but I would say it has a mid range overall volume. It was a little louder than I wanted so I experimented with two 3" vibrant resonators in the tail pipes. It cut the dbs slightly and took a good bit of the dfm sounds out. It actually made the exhaust even deeper in tone so the slight drone was unchanged.
Overall I like it but if hearing the dfm changes drive you crazy this might not be the exhaust for you unless you purchase a device to keep it in v8 mode all the time.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
