New Mobil 1 Oil out
RyanbabZ71
Today while at walmart i decided to look at the mobil 1 oil to see what they had.  TO my surprise they have the new Mobil 1 motor oil (formulated for newer engines?).  Bottle looks slightly different.  Price for 5W-30 was $4.77.  I heard it was gonna be $2.00 more a bottle but it doesnt look like this is true.  They didnt have a price per case but the 10W-30 was $28 something which is slightly higher i think but not much
Just thought id let everyone know
Also at the mobil gas station they had a sign for the new oil if you buy 6 qts you get a free mobil mug :(
Saw Mobil 1 in the local Fleet Farm ad on Sunday.  Ad was $3.94 a quart and to my surprise it was the new Mobil 1 as mentioned above.  Changing in 1000 miles.
Speaking of Walmart and Mobil 1, the ONLY reason I used to step foot into Walmart was to get the 5 gal jug of Mobil 1.
Now that they don't carry it anymore around here, I steer clear of that hillbilly infested place. :(  :(
Back to buying the little bottles  :(
Walmart here in MN has NOTHING!  Usually low on Mobil 1 quarts (have never seen a jug?) Never any AC Filters anymore.  Pretty much quit going there.....
The shelf was stocked full of M1 5W-30 i couldnt believe it.  usually i have to go to autozone or meiers (a nicer type walmart store).  Ill probably go to kmart and use my gfs discount from now on for oil might as well save a few bucks
Considering how little I have to change my oil( 2500 miles would equal 4-6months) and my truck is at what could be considered "Half-Life", 164 thousand miles, almost half of what they are known to run before a rebuild(although with the care I take I hope it'll last a lot longer), And the fact that my truck has probably always run "crude", I'm gonna get the new Mobil 1 SuperSyn, the time after next, cause rigtht ebfore I lost my job I bought enough for another oil change(thinking ahead).
It's actually been out for about two months now.  I go through so much Mobil 1 that I'm constantly buying new stock of it.  :(
Thank goodness this new oil is still PAO based.  I'm glad Mobil 1 didn't go the "fake synthetic" route like Castrol.
Welcome to the forum  :(
Can you elaborate on PAO based for us dummies (ok, maybe just me)?
I just tossed that new Mobil 1 in my Blazer last week before I went to Michigan for the weekend.  I've heard the previous version was better, this doesn't protect as well against wear.  That's only what I've heard on the edmunds.com boards though.  This newer version is the newest rating, SL, it was previously SJ.  I've got 1000 miles on it already!!  Going to Michigan quickly put just over 700 miles on my truck in two days!
Joe
You know us people in indiana.  We have the refineries 5 min from us and our gas is still higher than in most parts of the country and we are the last to get the new mobil 1 oil :(
Firecadet the new mobil 1 protects agaisnt wear much better.  Why would they change a product and make it worse?
Product Description
Mobil 1 fully synthetic motor oils are manufactured using non-conventional, high-performance fluids. These include polyalphaolefins (PAOs) and other ExxonMobil® engineered fluids which make up the Mobil 1 with SuperSyn™ formula.
The unique combination of high-performance fluids and proprietary additive systems enables Mobil 1 with SuperSyn™ motor oils to offer advantages beyond their conventional SAE viscosity-grade counterparts. Conventional mineral oils thicken or thin dramatically with changes in temperature.
To compensate for this weakness, manufacturers add thickeners to conventional multigrade oils to slow thinning as engine temperatures rise. Mobil 1 with SuperSyn™ fully synthetic motor oils have naturally high resistance to changes in viscosity due to temperature, and therefore require less of these thickeners. This results in a heavier, more stable protective oil film for engine bearings and piston rings than provided by similar SAE viscosity-grade mineral oils.
Mobil 1 with SuperSyn™ protects engines up to 204° C (400° F). It contains less impurities, so it protects better than conventional oils in cold weather (as shown by the pumpability limits indicated in the table below). This means that Mobil 1 with SuperSyn™ provides outstanding protection against wear at start-up, when most engine wear occurs.
Mobil 1 with SuperSyn™ is fully compatible with mineral-based or conventional motor oils. Any mixing of Mobil 1 products with conventional oils, however, will only dilute Mobil 1's many advantages. Mobil 1 with SuperSyn™ is also compatible with all other synthetic motor oils, but mixing synthetics is discouraged.
Applications
Mobil 1 with SuperSyn™ fully synthetic, detergent-dispersant oils are designed for passenger car and light truck gasoline or diesel engines requiring API Service SL, SJ or CF. Mobil 1 with SuperSyn™ 0W-30, 5W-30 and 10W-30 also exceed ILSAC GF-3 (Starburst Certification Mark) requirements.
Especially if the vehicle is still under warranty, owners should always consult their owner's manual for the correct oil quality and viscosity grade recommended for their vehicle.
Depending on the viscosity grade, Mobil 1 with SuperSyn™ motor oils meet or exceed the requirements of all major automobile manufacturers, including General Motors GM 4718M and Daimler-Chrysler MS 9615. Mobil 1 with SuperSyn™ meets or exceeds the more demanding European ACEA requirements and Japanese valvetrain wear requirements. Mobil 1 with SuperSyn™ 0W-40 is also approved for Mercedes-Benz MB 229.3.
Mobil 1 with SuperSyn™ is not recommended for 2-cycle or aviation engines unless specifically approved by the manufacturer.
Within the above API Service Classifications, Mobil 1 with SuperSyn™ 0W-30, 5W-30 and 10W-30 can be used anywhere an SAE 0W-30, 5W-30, 10W-30, 10W-40, 5W, 10W, 20W, 20 or 30 grade viscosity is recommended.
Mobil 1 with SuperSyn™ 0W-30, 5W-30 and 10W-30 improve fuel economy, exceeding the newest fuel efficiency rating – "Energy Conserving." Their cold-temperature performance is superior to conventional SAE 5W-30, 10W-30 and 10W-40 oils, easing the load on battery-started engines, especially at temperatures below -18° C (0° F). Owners of all cars should follow the car maker's recommendations for oil drain and filter change intervals.
Mobil 1 with SuperSyn™ 0W-40 is formulated for newer European cars, especially those with advanced-technology, multi-valve engines. It can be used where an SAE 0W-40, 0W-30, 5W-30 or 5W-40 grade viscosity is recommended.
Mobil 1 with SuperSyn™ 15W-50 can be used where SAE 15W-40, 15W-50, 20W-50, 15W, 20W, 20, 30, 40 or 50 grade viscosity is recommended.
Mobil 1 with SuperSyn™ 15W-50 is especially suitable for high-performance cars, particularly hot-running or heavily loaded vehicles and supercharged vehicles.
Mobil 1 products, race-proven under severe conditions, provide outstanding endurance and performance.
I paid $4.99/quart, up from ~$3.89 last time, so the new isn't as much more as I had feared either.
Still ~$5/quart for oil, kinda hurts some!!  As I said before, I'll put up with it for now.
Like Ryan, I doubt very much that Mobil would make a lower quality product - they have too much "riding" on the quality, IMO.
There's more than corn in Indiana?  :(  :(
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,227 Guests (See full list)
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
