First Alexa impressions
Alexa showed up yesterday, and although it was quite buggy to get it set up, I got it to work eventually.
Here is my experience:
Installing: Go to apps - my apps and click update on the internal api component, or any other thing that requires update.
Install Alexa if it’s not installed
My installation gave me error 101 at this point. Did not recognize the API component update. Turning off the system and restarting solved it
The rest was simple. Connect Alexa to your amazon account and you are good to go
The good:
Great integration with the vehicle: navigation, music, steering wheel button, phone contacts, calls, DIC - Just works natively. Awesome
It is Alexa- home automation, skills - great!
The bad:
Music is only amazon prime. No other services. At home, I use Alexa to play Apple Music. At the car, I can’t.
Have not tested drop ins. Did not work for me although it should.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 759 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
