Hi Everyone I did a compression test on my 2002 gmc sierra It has a SL - V8 - 5.3L 5328cc 325ci I am looking for the compression spec and can't seem to find it on the web I am getting about 135 to 145 on each cylinder. Not sure what the spec is. Any help would be great.  The engine is running like crap so I am doing new plugs and wires and a compression test to start with.  When at idle the tail pipe has a very strong smell of gas. When I back up the truck bucks. After a few minutes when the truck warms up and I step on the gas there is a lot of smoke out the tail pipe. Rough starting as well. Those are the issues I am having. Her is a link address on you tube
https://youtu.be/xkrSI28xHBc  This is a video I made of the truck on rough idle. Thank you for any help.
The numbers you get from a compression test will vary somewhat depending on the altitude at your location.  In theory, a perfect test result is the compression ratio times the atmospheric pressure.  So for a 10.25 cr and an atmospheric pressure of 14.7 psi, a perfect test would be 150 psi.  Mostly what you should be looking for is a very small variance from cylinder to cylinder.  A total variance under 10%  is usually considered good.  You didn't mention the individual cylinder number, but if the low was 135 and the high was 145, it seems ok to me.
From your description of the issues, it seems you may be running rich.  I'd be looking at the O2 sensors and maybe the MAF and IAC valve.
Very good ty I was thinking O2 myself. Where is the MAC and IAC located and do you have a pic for me to look at on those valves.
IAC is on the throttle body and the MAF is between the air filter box and the throttle body in the intake tube.
So here is an up date. I put in all new wires and plugs and did a compression test. The Compression test look good  all between 135 and 145 so that ruled out anything broke in the engine. But what I did find out is one of the plug had gas in it. I could dump the clean gas out of the plug on to my table. I repeated that process twice and both times when I took the plug out it had gas in it. Question could a dirty fuel injector cause that ? I also put a spark plug tester on the wire and started the truck and I had good spark coming off the test wire, I saw the light coming on and off.  I am thinking dirty fuel injectors.
Her is a video on you tube of me stepping on the gas and the truck smoking. The smoke has condensation  dripping out the tail pipe and a very bad smell of gas.      https://youtu.be/Am_GreAFMsU  Please Help. TY Regards Wolfie
Is it only that one spark plug that had lots of gas?
If so, maybe try swapping the injector for that cylinder with another cylinder, say, on the other side of the engine, and see if the gas on the spark plug problem follows it.  If it does, I would just replace the injector.
If you have a more advanced code reader that can do diagnostics, you could do an injector leakdown test.  That would tell you if one injector is putting out too much gas, but not if one is leaking.
2 had gas in them by the way. I will move them to the other side of the motor Drivers side. That bank was clean no issues. I think they are leaking. I will work on that and see what happens.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   2 Members, 0 Anonymous, 600 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
