This might be normal, who knows anymore. But when I start accelerating, only from a complete stop, I feel a slight tick in the steering wheel. Not necessarily a vibration, more so a tiny movement or click. Anyone had this before?
No sir, I do have a leather creaking type sound when turning then wheel though, its faint. I tried lubing the shaft "no pun intended" but it didn't do much so I turn the radio up and can't hear it. Haven't owned a vehicle yet without some kind of annoying noise be it Honda, Toyota or Chevy so I live with it.
Mines less of a noise, more like the tap of the steering column. I know it’s small, just figured it might be moving parts down there.
My 2019 Sierra does this as well. I have no idea what it is, but your description is spot on.
Glad im not crazy! It becomes super noticeable. I'm sure it is nothing bad. Are you bringing it to your dealers attention?
No not at this point. I only have ~7000 miles on mine. But if it gets worse over time, then I’ll take it in before warranty runs out.
Same. Mine has 7500 miles. It's nothing major, just bugs me.
I am having the exact issue on my 2015 Sierra Denali.  Did you find the cause?  For me it’s only after I turn the wheel right and then slight press down on the wheel it’s as you described.  I changed intermediate shaft but that didn’t resolve.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,208 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
