2017 1500 Leveling Kit UCA Problem
New to the forum, first time posting.
I have a 2017 1500 Silverado LT, 3-inch MotoFab leveling kit, wheels are Chevy stock CV32, 20x9, 28mm offset, 6.1 inch backspacing, have installed a 1/4 inch wheel spacer.  The 1/4 inch (6.35mm) spacer was installed to stop rubbing of the stock Stamped UCA. Tires are 275/60/20.  I'm what to install a new UCA that corrects the UCA ball joint angle. Problem is,  ll the UCAs I've  looked at require 4.5 inch backspace or less.
Need to find a solution.  i.e. UCA and Spacer; spinal and UCA; lower to 2" and keep stock UCA.  Any help that y'all can provided would be appreciated.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 743 Guests (See full list)
