Electrical gremlins
beetle
2014 SLT purchased new. Shortly after, started having issues with power mirrors not folding, power pedals not working, power lumbar stopped working (dealer replaced it twice) bottom of driver power seat stopped working. Returned to dealer several times, they were able to get them working but stopped again after just a few days. Since then these items would intermittently begin working again, then stop. When I try to operate them, I can hear a relay somewhere clicking but no action. These are not life and death issues that I absolutely need to have work since I'm the only driver, my concern is a catastrophic electrical failure leaving me stranded on the the road somewhere. Any ideas ? Thanks
