On 1/1/2021 at 3:52 PM, wirewrangler said:
All,
I just pulled F47 on the passenger side of the truck and put it back in; 5 seconds or so.  This worked for me - good luck everyone...
Wes
Thanks for clarifying that it is in fact the F47 fuse. I had this happen yet again today... a message came on my dash screen that the exhaust filter needed to be cleaned. I selected start, and of course it caused some of those items like the digital speedometer to disappear again. Popped the F47 fuse out and back in, now good to go... bizarre glitch that GM needs to figure out.
Thanks for the info! Had the truck to the dealer for this just after the new year. Got the message about cleaning the exhaust filter yesterday & yep... trip odometer etc was gone again! I’ll pull F47 and see if that fixes it. Hopefully they get this glitch figured out.
  • 3 months later...
Truck is at the dealer for the second time.  The first time they told me that it might be fixed - nope, not fixed.  This time, waiting for them to hook it up and call Detroit - confidence low...
  • 3 months later...
  • 10 months later...
I have a 2022 GMC 3500 HD Denali and my odometer and trip are not visible. Everything else is on the cluster. We’ve pulled the F47 fuse and unhooked all batteries, but still nothing.  I’ve called the dealer and they don’t know enough on the 2022 to help. Has anyone heard of a fix?
This is certainly not what we like to hear, Mommy4.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 GMC 3500 HD Denali. To do so, please send an email to [email protected] with ATTN: Mommy4/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 481 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
