Hey guys,
I've been searching the forums for my particular issue, but have not found it.  I have a roof leak right at the pillar between the front and rear doors.  I first noticed it a few months ago as a stain in the headliner right under the roof ditch.  It was only after a drive through car wash.  I was able to replicate a couple times with the car wash, but never during a rain.  Well, light to moderate rain the other day and more staining.  No SUNROOF, too far back for the shark fin and wrong side.  Too far forward for the third brake light, as there is no stain from the back.  just above the trim between the doors.  I'm out of warranty and can fix general things myself.  Do I order a new molding and rip mine off, hoping i can seal it myself?  Is there a gasket up there, or seem sealer?
9 hours ago, Zep5.0 said:
Hey guys,
Welcome to the site.
I would put money on it being the 3rd brake light. Water travels, and does not always leave stains behind. It is pretty busy underneath the headliner, so the water has a lot of places to go.
I stopped at the dealership body shop. They have never seen it like this either. They are going to keep it for a day and try to replicate the leak. Said it would cost a hundred bucks or so for a couple hours labor.
Their thought is the seam sealer may have a crack in it. Didn't think the 3rd brake light could travel that far especially with the leveling kit, it doesn't have a good way to run down.
We'll see what they say on Tuesday when I bring it in.
Thanks for the reply, have been on these forums reading for a few years now
You are very welcome.
Points of entry discussed over the K2 run were Sharkfin, sunroof, windshield, 3rd brake light, and a couple of posts about the seam holding the roof and cab together.
This turned out to be a decent hole in the seam sealer.  Gm shop only charged $107 to repair it as they popped off the trim and could easily see the issue.  Likely has gotten bigger with time as the sealer shrinks.  now a week later, I get to replace the AC compressor.  just did the condenser a few months ago.
At least repair #2 was not too bad, money wise.
Seems like anything in life, bad issues come in 3's.... Hopefully this is the last for a while.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
