Hi all,
My 2014 Silverado 1500 LTZ has an oil level warning come up on the centre console. The dipstick shows plenty of oil (it's just has 8 quarts put in at the local dealership) so I'm thinking it is the oil level sensor.
My problem is I'm struggling to find the part online. Does anybody know the part number?
Edit: is this it? https://www.wholesalegmpartsonline.com/products/Chevrolet/2014/Silverado-CREW-CAB-LTZ/Engine-Oil-Level-SENSOR-SWITCH/10488077/12639127.html
Edit: this looks like you have to remote oil pan to replace. I was hoping the oil level sensor was one of the screw in ones from the side of the pan. Could anybody confirm? And if so what part I need.
Thanks everyone.
Edited by Stuart W
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 846 Guests (See full list)
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
