I recently purchased a 2013 Sierra 2500 and noticed that the voltage is showing about 10v on the dash. I went and tested with my multi meter and its about 12.6 on the battery and 14.4 while running. I'm trying to figure out what to check next to see what would be causing the low voltage to display. When I turn on the truck, the gauge is pretty slow to get up to the 10v mark and doesn't really move when I turn things on. The previous owner changed all the lighting and added several aftermarket lights to the truck, so I'm wondering if maybe something was wired wrong, but I'm not sure where to check first.
Grounds in the cab and engine compartment would be the first thing I would check(for the ecm and bcm).  Could also be a gauge problem.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
