What is the low tire tire pressure threshold before a light or warning is triggered?
I just bought a 3500 and want to lower the pressure and eventually, hopefully, get the thresholds reprogrammed
I don't want a light or warning. I am assuming even on the 3500s it is a warning system, not just a information system?
On my Ram 3500. I could run the pressure as low as I wanted and never get a light or warning. Just a number.
i would run 50 front, 40 rear on my 35s
thanks
I have a srw 3500 and the light will come on if the tears are below 60 psi fronts I run at the recommended 60 so I can’t speak for that.  The 60 in the rear helped my ride out a bunch and I just bump back up when I tow my equipment trailer.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
