What is the best way to get front grill and rear tailgate emblems black in center?  I wrapped them in vinyl twice and they peel etc. after car washes and driving around..
Use best quality vinyl. 3m and Vivvid are two. Had mine done with Vivvid. No issues for over a year then got a OEM black front one cheap.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,153 Guests (See full list)
