Selling and GM accessory Onyx Black locking fuel door for 14-18 Silverados. Replaces factory door and locks very well. Door is in very good condition. I traded in the Silverado for a newer truck and kept this door. Comes with 2 keys. Asking $110 shipped (PP or FB messenger) to the lower 48. PM me if you have questions. Thanks!364dfc77da1176b938201b74387cd876.jpg
  • 1 month later...
  • 1 year later...
  • 1 month later...
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
