Good Evening All,
I have a 2014 Silverado 1500 LT Z71. Aftermarket LED headlights and tail lights. Never have had any issues with them but yesterday my running lights just randomly stopped working. My low beams come on but that is it. No side markers up front and no brake lights in the back when I'm in drive or when I remote start the truck. The brakes work when pressed but at night they don't light up until they are pressed.  Turn signals work up front and in the back. Reverse lights work. License plate light works.
I saw a video on youtube of a guy who has a 2016 who had the same issues in the rear and he bypassed it using a butt connector but it wasn't detailed enough for me to do based off the video and quality. Doing that also wouldn't fix the fact my front running lights won't work (the amber blinkers). I could live with the front ambers not lighting up but I'm more concerned with the brake lights not illuminating in drive at night.
I know the running lights are controlled by the BCM. Is there a good chance this has gone bad? Anything I can do to test and see or is this something I need a dealer to test.
Looking for any suggestions. Thanks
So the fuses were blown. Replaced and they blew immediately. Replaced the relay and the fuses again. Fuses blew again. So I’m assuming some sort of short. Could it be the bcm. Any suggestions?
Hi I have a 2018 gmc sierra 1500 and tailight running light doesn’t work and the front daytime running light doesn’t work on the right side and also I tried to install an aftermarket led tailight but when I connected it I smelled some burning what could be the problem thank you
  • 5 months later...
Was this issue resolved I’m having the same problems as Ludgero with the right side running lamp in the rear and front DRL is not working.
Hey guys any update running into the same issue with my 2017 GMC Sierra and this is the only article I’ve found so far , all my lights work like , break , reverse , left signal, but my light doesn’t stay on for break and the running light around the normal lights up front.
Edited by Gmctrucks0848
  • 9 months later...
having an issue with my daytime running lights. only one of the 2 on each headlight come on. the bottom one on the passenger side comes on and the top one on the drivers side comes on. But when I hit my lock and unlock button on my key fob all 4 come on. I checked the 2 fuses for the drl's and they are both fine. anybody have any ideas on what to check next?
  • 2 years later...
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 525 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
