I have a fuel leaks that are between the tank and the portion of fuel line that first turns up headed past the transmission and into the engine bay.  I purchased replacement nylon fuel lines but I hate to wrestle(jacking up the cab etc.) with removing and replacing the lines that run past the transmission and into the engine bay if I do not have to, these lines are in good condition.
What would be the best way to replace the lines between the tank and just past the 90 degree turn where the lines turn up towards the engine bay?
Does anyone have any experience replacing just this portion of the fuel line?
Should I use a compression fitting to go from metal tube to nylon fuel line?
Should I try to flare the metal lines(not sure if there is room) and run fuel injected compatible rubber hose from the steel line to a male to male barbed coupler to connect the rubber hose to the nylon hose?
As was posted on another forum, you might want to consider cutting out the rusted sections and using NiCopp line, compression fittings and compression unions to make repairs.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 929 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
