hey guys, new guy here. Have a 2010 silverado crew cab 5.3, i had the lifter collapse so i ripped out the whole afm system out replaced the cam, lifters and vlom delete. everything was fine but after a few years now i have lifter tick. Oil pressure isnt low but could be better, is this why i have lifter tick? i dont want to run motor flush as service bulletins advises against it and says it damages seals and bearings and cause oil starvation. im planning to swap out the stock oil pump with the summit oil pump 121170 version of the melling 295 so it has standard volume not high volme but +10 psi so not too bad wont run the oil pan dry or low. Will this most likely fix the tick? also, is it possible to replace oil pump without dropping the oil pan will it come out by just taking the timing chain cover off would i be able to put it back on effectively if so (no leaks)
Is this a RWD or 4x4?
    Tbhats2130
    Tbhats2130
  • Who's Online   5 Members, 0 Anonymous, 1,056 Guests (See full list)
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
