Hello everyone, i hope im posting in the right area. I own a 2000 GMC Sierra 1500, and im wanting to upgrade to some aftermarket wheels. I found a liking to the Fuel Mavericks, but the ones that fit my vehicle to a t have to much offset on the spokes for my liking. I have found another pair that i like, but the bore is alot higher then stock (its like +30) and i was wondering if it would be dangerous to run them?
Stock rim bore: 78.1
Rim i want's bore: 106.1
You’ll be fine with plastic rings. My wheels are 106mm bore and I use the plastic rings that came with them. I have 10ply tires and I’ve hauled as much as 2,000 lbs in the bed and towed my 7k lbs trailer multiple times with no issues whatsoever.
Sweet. Another question, I called a shop and they told me they dont run rings, especially when mudding because water gets behind the rings and rusts. That true?
What is it going to rust?
The plastic or the aluminum rim???
Water, salt and mud can already get over everything else so I have no idea what they are talking about. Put some anti-seize on the brake rotor, hub, centric ring and won't have any problems.
They said the rim would. Water would get in there and sit, and rust the rim.
The rim is aluminum and doesn't rust.
Put some anti-seize on the stuff and it will be fine.
    Enduro73
    Enduro73
  • Who's Online   1 Member, 0 Anonymous, 991 Guests (See full list)
