Sylvania XV's
AssKickinHD
Just bought the Sylvania XV's and I must say that I am rather dissapointed! :flag: Cant tell the difference between these and the stock ones. d**n near axactly the same! Spend the extra money and buy the Silverstars!!!! :lol:
Oh well, guess ill listen and buy the Silverstars next time!! :wtf:
My 2 cents......
:D
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
