I decided to buy a redarc tow pro elite for my 15' chevy 1500. I was originally going to go with another brand that had a plug and play wiring adapter so that i didnt have to deal with the one that came with the truck but i read thats not possible with the one.
Can someone help me through the electrical part of this? Are the listed items below correct? Also can someone please clarify what to do about the 20 amp fuse/30A breaker/ positive battery terminal?
Also, should i use electrical tape or shrink tubes?
Truck oem wiring harness
Dk blue - brakes out
Red/grn - battery
Wht/blu - brake signal
Blk - brakes ground
Redarc brake controller
Blue - to 12v trailer brakes (goes to dark blue?)
Red - to 12v trailer brakes light trigger (goes to wht/blu?)
Blk - 20 amp fuse or 30A circuit breaker THEN to battery positive terminal? What? Lol (red/green?)
White - ground (goes to blk?)
Edited by consoleman
Brake controller black to truck red/green.
Brake controller blue to truck dk blue.
Brake controller red to truck white/blue.
Brake controller white to truck black.
Sent from my SM-G930V using Tapatalk
Thanks Joe! That gets me out of a bind.
I want to install this right above the light knob like the picture attached. The drilling instruction recommend at pilot hole first (maybe a 1/8"). Did anyone use a center punch first? Just worried the drill may slide around it being plastic.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
