04 Sierra 1500 won’t start on first try but always starts on 2nd try. It has good fuel pressure that is 60psi and the maf sensor is good and the evap purge is good. Also has new crank and cam sensors.
One thing to check is the leak down fuel pressure after you turn the key off. There's a check valve on the fuel pump that keeps fuel in the line. If it fails then each time you turn the key on you have to pressurize the entire system.
Does it do it every time you start it? Generally first start of day?
iirc, do the key on, key off pressure test and observe the reading. After key off of it drops more than 5 psi in minute you've got an issue. Either a leaking check valve on the pump or an injector leaking
Edited by txab
The fuel pressure is good and it just does it at any random time. I can crank it in the morning after sitting all night and it fires right up but 5 miles down the road it won’t start on first try but always on the 2nd one. It just seems to happen at all different times regardless of engine temp or how long it has been sitting. This never happened before the shop changed the cam sensor but they have checked and rechecked it and say it’s fine.
Edited by Jason29160
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
