Was looking at the rear end yesterday in preparation to install my shackles. I’m assuming that to remove the shackle from the leaf spring, I’ve gotta lift the frame high enough and drop the axle low enough to get it below the frame so I can slide the bolt out. Or is there a hidden hole I’m missing that I can slide the bolt through? I’m not talking about the shackle from the frame bolt, I found that hole. I’m talking shackle to leaf spring bolt.
Edited by Centex14
Loosen the tie bolts and lower the axle. If there's a shim/spacer (depending year/model) spin it 180°. What truck?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,211 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
