My best friend has a 2001 Chevy 2500 4x4 that he uses to tow his horse trailer. He has an intermittent front end shake at all different speeds and different roads. He's not real mechanically inclined and usually has me work on his truck for him. I'm really at a loss cause the issue is so intermittent and random. Because of this I've ruled out tires, hubs, and shocks cause these would be more consistent. I've been researching alot of the questions on this and other forums but most are for a constant vibration not an intermittent one. I have seen some suggestions that it could be the 4wd system trying to engage the front end?? Also read that it may be the transfer case?? But honestly havent really seen much for a very random intermittent violent shaking that happens at all different speeds, sometimes towing the trailer and other times without the trailer. Has happened on city streets, freeways, back roads etc. Usually just slow down or pull over and stop and the issue goes away. He is the original owner, truck is completely stock, has 155,000 miles, just replaced the ABS module and front tire rod ends. Has brand new tires that were just balanced and alignment. Anything else let me know and any suggestions will be greatly appreciated!! Thank you.....
Just dealt with this on a '04 model 2500HD . Since I wasn't sure, I changed the T case fluid and added some motorkote to it. Looked for a wear spot in the housing as well. That did NOT fix it. Off to the front, Not the hubs as I just did them, and the brakes were fine. I took off the skid plate ( this truck has them all) And then drained the front axle housing. The oil was ugly and very dirty, and low. Probably original.  Was hard to tell if it leaked due to so much leakage from the stock oil cooler or heater lines that always leak. Changed that fluid with 75w-90 and added 2 ounces of motorkote to it.
Tried all sorts of situations and could NOT get the vibration to come back. 60 miles. 152K on this truck.
Seems like The front diff carrier bearings were shuddering, but thats a guess.
Looks like success.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,588 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
