Big trucks inside
The SPEEDY
wow, that F-250 at the bottom of the page has quite a lift. although I've seen a Ram in town with about 8" more though.....
Just my personal opinion... If I was going to spend that kind of cash on my truck, it sure as hell wouldn't look like that!!! There are alot nicer tire wheel combos than that...
Hey though, it's cool that somebody tried it!!!! :devil:
The tire price alone would break your wallet. As the son of a man who owns 7 big rigs, I know that the tires needed for those wheels cost a fortune
Ouch and you always see them on the sides of the highway in pieces. Are they recapable?
If there is anything to make a truck slower.. That would be it!! Big ol 22.5's on a small truck... That better be one HE// of an adapter to get those wheels on those trucks. Sure hate for it to break while running 70 down the highway and a wheel or two fly off!!
K1500 is ordering some of these as we speak!!! :mad:
Actually just ordered a full set of alcoa 22.5s yesterday for a tandem axle truck with the fronts being super singles which carry 425-65-22.5 tires . the rears are just regular 11 22.5s
OUCH! That thought alone is giving me the creeps. :mad:
The retread is what is on the road. Cheap way around new tires, but not as safe.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,225 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
