Considering Sumo Springs for my 2019 AT4.
I carry 1500lbs + of deer corn or fertilizer in my bed periodically and the rear sag is bad. I only have to drive about 10 miles loaded like that
Anyone with experience using Sumo Springs to lessen sag when the bed is loaded?
When I tested them on my Ram, they only had 1/4 inch or less of air gap, which means, any thing other than a small bump would cause the shocks to contact and begin compression and it totally wrecked my ride quality while unloaded.They are color coded, and I forget what color (blue vs black) I had, but they were the medium duty ones, possibly the lighter ones would be less stiff and jarring on contact.
Have them on my 2020 at4 and love them, yard of stone only dropped it 2 inchesb43979087ee64bc92d78a9b89c7a5e84.jpg63fdf1a5a0f49669d3cea17c7370b271.jpg
Sent from my SM-G973U1 using Tapatalk
Is that photo with sumo springs in use - you are right on top of the bump stop.  I have 2020 AT4 and tow quite a bit.
Been looking at this option to help with tongue weight of car trailer - have load leveling hitch and that helps a lot, but looking for something more.  Last truck (14 Raptor) I did Deaver spring pack and they custom tuned for tongue weight - so worked great, eliminated the rear block etc.  But $1,200 for spring pack, which is more than I want to spend if sumo spring will for a few hundred dollars.
Thx for any more info. 649394741_2020AT4w-trailers.thumb.jpg.2703ef3e644cd0af3c16d84403f6d586.jpg
Kyle, are those medium duty Sumo’s?
a yard of stone is supposed to be 2400 pounds. Is your truck a half ton?
currently I limit my loads in my half ton to 1500 pounds. But it sure would be easier to load a 2000 pound pallet of material (corn or fertilizer) at a time
yeah, I know that’s over payload capacity
Thanks Kyle. Last question - is the picture of the spring with the load of stone in the bed or unloaded? I assume unloaded. Thanks again
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,827 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
