Hi there - 2020 AT4 6.2L Sierra owner here - every once in a while upon turning off my truck, I'll get a rapid horn honk burst similar to when you leave you keys in the truck...it's almost like it is trying to notify me of something...I had some DTC's stored in memory...I wonder if that is the cause and I should get them cleared by the dealer (or get a tool to do it myself)?
Any other ideas?
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
