Hello.
I am new here, but have been reading/lurking for a bit.  I have a '19 GMC 2500 Denali.  For all of you that have made changes to your center console, either swapping one out or putting one in, I have a couple of questions.
I would like to change out the 12v adapter on the backside of the console with a rocker switch.  I have looked and found an exploded diagram of it, but just not sure how to get the back cover off.
1.  Does anyone have any pics of the underside (at the rear) of the console?
2.  Has anyone pulled the back cover off to get to 12v plug?
3.  I figure it pops off, but how does it come off?
Thanks in advance.
Hello.
Thanks in advance.
Holy crap lol, I was looking for threads and other forums for this, last week and this week. I did this mod Sunday night. This has got to be fate man lol! Hopefully this is the same access for the 19 Denali. I have a 2015 Chevy Diesel 2500HD.
There's 4 torque screws on the side. You can see the top two by just looking in, the bottom two you have to pull the rubber sleeve out and you can see them. The scary part is pulling off the back. I'd say lift up and towards your head(it takes some force). I absolutely hate and always get scared of breaking clips or plastic inside. The second pic is the QC charger I went with, its solid and charges fast, found it on amazon for like $13. You also have to bore out the existing charger hole for this QC charger to fit, but that's not hard either.
Thanks for the reply.  So, what's it take to get the back cover off?  Sorry, I didn't read it all.  I found the easy ones.  I will look again for the hidden screws.
Edited by HallettMan
Lol no worries I was mad for a second,
cause I explained it in my reply [emoji1787]. The bottom two screws are hidden behind the rubber lining that pulls out on the bottom.
cause I explained it in my reply emoji1787.png. The bottom two screws are hidden behind the rubber lining that pulls out on the bottom.
Yeah, I glanced at it and went straight for the pics.  My bad.
Do you happen to have one of the rubber piece and the back.  I'm not sure if mine has that.  I will have to go look again in the morning.  I think they are all about the same from '15 - '19.  It looks pretty close.
I found a pic off eBay, if yours looks like this the rubber sleeve inside there pulls out. It's almost camouflaged lol.
I will have to look tomorrow, but I'm pretty sure it looks like that.  You are right.  I sure didn't see it.  I found a exploded diagram and it shows it.  Thanks.  I'll post up what I find tomorrow.
Got the cover off.  Once I figured it out from all the info, it came off pretty easy.  Thank you for the help.  I found there is enough room behind the cover to do what I want so, I am going to add an additional device inside the upper tray.  Should work out fine that way.  Again, thanks.
Right on man, I was wondering if you were able to get it and how it turned out.
If you remember, take some pics and post them up to see the turnout.
Funny little mods like this we just do, I forget to post them for reference.
Still waiting on my parts, but I will be ready when they get here on Saturday, I hope.  I will try to take a few pics and post them up.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
