Hello.
I am new here, but have been reading/lurking for a bit.  I have a '19 GMC 2500 Denali.  For all of you that have made changes to your center console, either swapping one out or putting one in, I have a couple of questions.
I would like to change out the 12v adapter on the backside of the console with a rocker switch.  I have looked and found an exploded diagram of it, but just not sure how to get the back cover off.
1.  Does anyone have any pics of the underside (at the rear) of the console?
2.  Has anyone pulled the back cover off to get to 12v plug?
3.  I figure it pops off, but how does it come off?
Thanks in advance.
Hello.
Thanks in advance.
Holy crap lol, I was looking for threads and other forums for this, last week and this week. I did this mod Sunday night. This has got to be fate man lol! Hopefully this is the same access for the 19 Denali. I have a 2015 Chevy Diesel 2500HD.
There's 4 torque screws on the side. You can see the top two by just looking in, the bottom two you have to pull the rubber sleeve out and you can see them. The scary part is pulling off the back. I'd say lift up and towards your head(it takes some force). I absolutely hate and always get scared of breaking clips or plastic inside. The second pic is the QC charger I went with, its solid and charges fast, found it on amazon for like $13. You also have to bore out the existing charger hole for this QC charger to fit, but that's not hard either.
Thanks for the reply.  So, what's it take to get the back cover off?  Sorry, I didn't read it all.  I found the easy ones.  I will look again for the hidden screws.
Edited by HallettMan
Lol no worries I was mad for a second,
cause I explained it in my reply [emoji1787]. The bottom two screws are hidden behind the rubber lining that pulls out on the bottom.
cause I explained it in my reply emoji1787.png. The bottom two screws are hidden behind the rubber lining that pulls out on the bottom.
Yeah, I glanced at it and went straight for the pics.  My bad.
Do you happen to have one of the rubber piece and the back.  I'm not sure if mine has that.  I will have to go look again in the morning.  I think they are all about the same from '15 - '19.  It looks pretty close.
I found a pic off eBay, if yours looks like this the rubber sleeve inside there pulls out. It's almost camouflaged lol.
I will have to look tomorrow, but I'm pretty sure it looks like that.  You are right.  I sure didn't see it.  I found a exploded diagram and it shows it.  Thanks.  I'll post up what I find tomorrow.
Got the cover off.  Once I figured it out from all the info, it came off pretty easy.  Thank you for the help.  I found there is enough room behind the cover to do what I want so, I am going to add an additional device inside the upper tray.  Should work out fine that way.  Again, thanks.
Right on man, I was wondering if you were able to get it and how it turned out.
If you remember, take some pics and post them up to see the turnout.
Funny little mods like this we just do, I forget to post them for reference.
Still waiting on my parts, but I will be ready when they get here on Saturday, I hope.  I will try to take a few pics and post them up.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
