2003 z71 extended cab stepside bed.
Battery keeps draining over a month or so. I noticed tonight when the key was out door is shut, the battery light and highbeam headlight indicator are both lit very dim..
The dome light does not turn on when I open both doors, but I can operate it manually from the dimmer switch, while doing the dimmer switch I can see the highbeam indicator is still dim but brightens up and goes back down. The battery light is staying at the same dim state. I'm not sure which fuses to look for if there is a "cluster" fuse or something?
Anyone experienced this? Any help would be appreciate.
The picture isn't the best, but thats how they are.9b36c26cc19bc815ee855fd3f73b1425.jpg
Sent from my SM-A515U using Tapatalk
