I have a 2020 Silverado custom and was wondering if the grille assemble is all one piece, or is the piece that is color matched and says "Chevrolet" a separate overlay that snaps into the actual grated part of the grille? The piece I'm questioning is circled in the picture. I've been looking at parts diagrams online and I can't tell.
You have to take the whole grille assembly out and then the center (White) part will separate from the main grille.
  • Thanks 1
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 682 Guests (See full list)
