Does anyone know anything about removing the magnetic shocks from a 2020 Denali?
Ideally without any lights on the dash.
  • 1 month later...
I wish my 2019 High Country had it. The 2021 do know.
Why do you want to get rid of it. They ride so nice with it on
I drove a 2019 2SS with magnetic ride count roll and couldn’t believe how well it drove compared to the regular SS
I had a 2017 Suburban with it and the fronts failed at 50k.  My mechanic wanted $2600 JUST FOR THE FRONT.  I bought parts independently, installed them myself, and saved $1600.  Then I traded the Suburban off for my Silverado.  It never did feel right.
The wife has a 2016 Tahoe with the same system and nearly the same amount of miles.  It hasn't failed yet, but when it does, I'll be swapping to standard struts and shocks and using a bypass kit (to prevent lights and error codes) from here: http://shocksims.com/.
I would say the ride with Magna Ride is marginally better, but my 2020 Silverado LTZ rides as good or better with a standard suspension.   And, I can't see spending $4K-$5K every 50K miles to replace the shocks, especially when I hit 50k in two years on the Suburban.  The cost isn't worth it to me.
Well I have just ridden I a new Denali and compared to my High Country it is night and day. To each their own. When I get my 2SS convertible it will be with magna ride.
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
