My Trailboss used to act just like all others described until I switched to Bilsteins. In my opinion I'd change the front and rears (some only change the rear) and as another member said on this string you will think you purchased a better truck! The dampening on the Bilsteins is night and day and I was actually shocked how much tighter the truck feels.
I agree it looks like a 2" lift. Can't see from the picture if it's the GM kit or the poor man's trail boss (2" spacers up front and 2" rear blocks). Look between your rear axle and the leaf springs. There's no block from the factory, so if you have a 2" block, you have a 2" rear lift. Same up front, if there's a spacer above or below the strut, it's lifted (about 1.3" spacer = 2" of lift). That would be a poor man's trail boss. The real GM kit uses longer front struts without spacers, but it will have rear blocks.
I gave my Z71 truck the poor man's trail boss treatment, and it would hop all over going over bumps or even just train tracks in town I had to be careful to keep the ass end of the truck in my lane. That problem completely disappeared when I installed a BDS lift with Fox shocks. The tires stay planted on the ground at all times now.
  • 3 weeks later...
It appears to be the poor man's Trail Boss. I out on some 5100s on the rear and that was definitely the cure. Those Ranchos didn't even try and extend out when I took them off. I'll go with the 5100s up front.  May remove the spacer and use the strut for that portion. What strut does the regular TB use?
Had the hard slam as well over s bumps.  Have 10 of them in my housing track before I get home.  Hated it, always go slow as well and still slammed.  Sounded like my gate was down.   Bilstein's ended that the day they were put on.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
