2014 Silverado 5.3L radiator fans turned on high while driving and temp gauge read cold. Got home shut truck off fans still on high. Disconnected neg. battery cable and hooked back up after a few minutes. Started truck fans weren’t on but gauge was cold still. Let truck run for 20 mins and gauge went up to 180 degrees. Drove truck around neighborhood and temp never rises. Got back home let truck idle for about 20 more mins and temp gauge moved to 210 degrees fans didn’t turn on. Fans never turn on while driving and temp stays at 180 degrees unless at stop light or drive thru then temp gauge goes to around 210 degrees. Could it be coolant temp sensor or thermostat stuck open?
Temp sensor sounds like it's having problems. If the gauge read cold but the fans kicked on high, usually the temp sensor is not working right.
Brought all the parts already. Do you think I should just change our thermostat when changing out sensor?
Thermostat takes me like 20 minutes tops. Super easy.
Edited by Grumpy Bear
Thank you so much. Gonna be changing out tomorrow and I’ll update post with how it goes.
Update: changed out thermostat and cooling temp sensor and temp gauge reading  normal and fans turn on and off.
There is a noise coming from near thermostat housing while idling. It’s like a whistling or whining noise. Not sure if thermostat makes that type of noise. Any suggestions would be appreciated.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 910 Guests (See full list)
