I have had a strange electrical problem with my 2015 Chevrolet Silverado with a six cylinder.  I first tried removing the grounds and cleaning them and tightening them up.  The intermittent problem still didn’t go away.  I could go to a drive-through at a fast food restaurant and I would try to turn the steering wheel but it would jerk back and not let me turn. I would have to turn off the truck and start it again and then it would work. The dashboard shut off when I touch the brakes or use the blinkers or roll up or down the windows after a long 3-6 hr drive I  would notice a strange noise on my stereo and it would turn off when I use the blinkers rolled down a window or stepped on the brakes.   I took my vehicle to a couple of shops and none of them experience the problem after two months of checking my vehicle.  I finally fixed it. I replace the fusible link sheet metal on my battery.  For six months now I have not had a problem.   I hope this helps somebody with a weird electrical problem.  It only cost me $60 used on eBay.
