Hey everyone!
so my blower motor went out. Checked all fuses. I bought a new motor but still no function. I have voltage at the actual motor.  But it won’t turn on.
my climate  controls work? I can hear the vents moving in the dash if I change from floor to windshield etc.
Edited by Moreno6.2
there is always power at the motor, the speed is controlled by ground inputs sent from the heater control to the hvac control module, check the ground connections inthe pdf i sent you
  • 3 years later...
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
