It's a 18 silverado with the 5.3 truck has a blower on it SLP1900 no issues until now. Went to remote start it this morning and it shut right off. Check engine light says it's 2 codes. P2635 fuel pump flow performance and P018b fuel pressure sensor performance. Other then the blower everything else is stock. I'm thinking fuel pump is going out. Truck runs fine starts no issues that I can tell. Any thoughts thanks.
Sent from my SM-G986U using Tapatalk
