I have a 2017 LT Silverado 1500 (Pepperdust) and I'm looking to swap to a 2500 front end. So far I know I need the bumper, headlights, grill, and hood. Not sure how I'm going to modify the headlight harness yet to go to those projectors in the 2500 headlights. If anyone has done this before, advise would be appreciated lol. Thanks guys
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 897 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
