What are your recommendations to clean the exhaust tips on a 2020 TB with. I have tried Chrome cleaner and it really didn't help much. Should I just cut my losses and paint them black? Any recommendations. TIA
I painted mine at home with some high temp spray paint (used for bbq grills).
3 hours ago, SilverBulletBoss said:
Those look awesome! Did you take them off to paint or just tape around the area?
Thanks. I took them off. It was kinda of a pain to get them off but worth it in the end. I used this spray can (1 can is more than enough). Cleaned them and used 200 grit sandpaper to sand them down. Did first coat kinda light and then 4 regular coats with about 30 mins in between coats. Then waited like 3-4 hours for it to dry and reinstalled them. Another option a lot of people do is to get them powder coated but this was like $10 bucks at home & completed within a day.
