Hey guys I’m new to the truck stuff. I installed the lift kit myself and everything went smooth. It’s a 16 Sierra 4wd installed 5 inch knuckle from rough country. After install I waited for my 2 inch spacers to come in before the alignment so I drove the truck to work to see any shaking on highway. Got the wheel alignment yesterday and I’m on the highway and it starts vibrating and my abs and stability light comes on. I turn on and off and it goes away. It only comes on around 70+. It never did this until I got a alignment. Took it back and they said it’s because I lifted the truck, wheels are off balance, or my wheel spacers. I’m still on stock 20’s. So now my other problem is when In 4wd it sounds like it’s grunting and not sounding like it should. I’m not sure what to do or what to look for. Any help would be appreciated. Thanks!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
