Looking for any feedback/experience with a 2017 Yukon. We bought the truck used a year ago, 3 months later, the a/c stops working. We took it to Firestone and they did a leak check and found no leaks but freon was low so they filled it up, $750 for the Freon. The a/c still didn’t work, I took it back and they still showed no leak but couldn’t identify issue. I found out about the special warranty and my truck was eligible based on year and mileage for the condenser repair. I took it to the dealership service department and they said the condenser was the problem and replaced it. Two weeks later, the a/c is not working. I took it to the dealership today and they said there is now a leak in the rear a/c tubes. They said this is not included in the warranty and will cost $1500. We did not purchase an extended warranty when we bought the truck...figured spending $36k on a 3 year old vehicle had a low chance of repairs within the warranty terms. So what is you experience with this? I find it hard to believe this couldn’t be due to the condenser repair and may be a result of faulty installation by the dealership service department. If you repair the condenser, wouldn’t it be possible that the rear a/c tubing could also need replacement due to the new pressure or should they have caught this?
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
