2014 Silverado 1500 (110000 mi) EMF reading on drivers side dashboard goes from ~1 to over 24 when truck is put in gear (any position other that "P"), when put back in "P", readings return to ~1.  What electronics are just under the dash that only get energized when in-gear?
