So me and my cousin got a hold of an official GM MDI so we can do an LS swap from a 2003 2500 Silverado and the issue I am having is the controller runs through its Bood up but the computer doesn't recognize it I recover it the computer will recognize it then and recover an update all the software but after doing so it does not go all the way through its boot process again I have taken it apart there was some slight battery corrosion but other than that I don't see anything wrong with it
