 A brief history first.
     I have owned this 2000 GMC 3 door 5.3Lt.  for about 15 years now, when I got it , the heater never worked well, but I changed the cabin filters a few times, the heater core, the thermostat and coolant , water pumps, belts etc.
 It would never blow hot air on my feet.
About 6 months ago during the start of the winter, I decided to change to mode door actuator , with a Dorman unit 604-113.
 The one that is above the drivers right leg.
 I had pure hell trying to twist my way in there and get it all aligned up  to install. I did it several times but always failed with the correct way the  dial on the dash said it should be blowing , but finally did get it installed.
 about a week later my "blend door " actuator quit working and stated  popping sounds when going from cold to hot on the dial. that was OK because it was stuck on hot.
 Now that it is summer  I bought a new Blend door actuator and installed it, no problem there.
 but I then noticed  that the mode door was not working as every place on the dial only blows out the defroster vent.
 I pulled the panel off under the steering column and looked at the Mode actuator as I turned the dial and the gears or the "wheel" on the actuator is not moving at all.
  Checked the fuses and all are good.
Did I do something wrong while installing the Blend door actuator? or did the Mode door just fail?
 The Dorman I bought had the "wheel" built on the actuator.
 Is there a video or something that would help me in getting the Mode door actuator off and back on correctly the first time? how to align the  2 doors on the wheel and the teeth on the other door.
 My heater control is the 3 knob type with no driver or passenger separations.
Ron
OK Update on the blend door I installed yesterday, this morning when I started the vehicle, I heard a loud popping and grinding coming from the blend door actuator I installed yesterday, I quickly turned off the ignition and  reached down and unplugged the  wiring to the actuator , maybe I didn't kill it.
   Although after installing yesterday, I dove it several miles and I listed to it turning when I moved the dial each time and nothing unusual  until this morning. When i installed it I turned the blend door with my fingers to the position that was on the actuator whish was straight across left to right.  then bolted it  up and installed the wire, turned the key on and the blower and moved the middle knob from cold to middle then to hot and back and it moved each time.
   So is the Mode door actuator that is not working now throwing a signal to the blend door?
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
