Getting a "Program Cluster" message everytime I start my 2020 AT4 3500. Just started after 14k miles. Everything seems to be working okay. Is there a way to make this message stop without making a trip to the dealer?
Edited by KKDuramax
Fixed error message from reprogram to program
  • KKDuramax changed the title to Program Cluster message
  • 4 weeks later...
  • 2 years later...
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
