I have a 2015 suburban that I purchased a couple weeks ago. The front HVAC blower stopped working. It was working one day, amd then not the next and it hasnt worked since. Its been about a week now. If you turn off the controlls and then turn them back on the fan kicks on for a second and then shuts off. If i turn off the auto mode so i can control it manually, i can turn the blower up to high and it still does nothing. From my experience with past suburbans or silverados, this is usually a bad blower motor resistor. I looked and cannot find a resistor in the front, then after talking to a friend of mime, he said the newer model suburbans dont have a resistor in the front. So my question is, can someone shed some light on this issue? If the blower doesnt work, does that mean the blower motor needs to be replaced, or are there other components to this system i am not aware of? Anyone have any experience with this?
  • 1 year later...
Having the same issue on my 2016 Suburban. There is actually no resistor on these trucks for the front fan, rather it's a circuit board attached to the blower motor itself that controls fan speed in relation to inputs from the rheostat-style dial on the HVAC controls.
I have seen a post on one other forum where a guy had his get wet due to a leak and replacing the whole blower motor/circuit board assembly solved his problem (I think). I'm actually replacing mine today in the hopes that it solves the problem.
If that's not it, I'll be checking my G218 ground posts under the dash by the windshield as outlined in this guy's video:
If that's not it, I'll be stumped.
It doesn't seem like a lot of K2 truck owners are having this issue right now but I assume more will as time goes on.
Edited by Prospect62
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 890 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
